O3a
O3a Cyanoacrylate Adhesives
SKU: 109158
€12,00
  • Stick with quality
  • O3a Cyanoacrylate Adhesives put you in full control
  • Available in three viscosities; Thin, Medium, Thick
  • Sets fast, whilst still allowing time to get the fit "spot-on"
  • Developed and manufactured in the UK
Developed and manufactured in the UK, O3a adhesive is a dedicated range of cyanoacrylates specifically made to meet the requirements of woodworkers, woodturners and craftspeople. These Cyanoacrylate Adhesives aka Super Glues are the result of much research and hundreds of test samples.
Over the past few years woodworkers and crafters have come to appreciate the usefulness of ‘super glue’ at the same time recognising many drawbacks. Some set too quickly, some set too slowly, some are too thick, some are too thin and in most cases don't set clear.
O3a Cyanoacrylate Adhesives put you in full control. Use the non staining low odour O3a Aerosol Activators to set the adhesive in less than 20 seconds. These adhesives give you just enough time to get the fit "spot-on right".
O3a adhesives are available in three viscosities; thin, medium and thick. These cover all situations ranging from wicking into hairline cracks using the O3a Thin to gap filling with O3a Thick. In between is the O3a medium for general use, all of which dry crystal clear. O3a offers endless fast fix possibilities. Stick with quality.
Made in the UK.
Suitable For Wood Ceramics Metal Rubber Leather Some Plastics
Adhesive Type Cyanoacrylate
Made in Britain Yes
EAN Barcode 5065010516069
