Axcaliber Pack of 5 Bandsaw Blades - 2,490mm(98")
718415
From £67.28 £56.07
66 Reviews
Buy two Axcaliber Bandsaw Blades, get cheapest blade free! Add two or more to your basket and use code: AXBB25
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Saturday 19th Jul
  • Pack of 5 x 2,490mm bandsaw blades
  • Pack comprises 1 each of:
  • 1/4" x 10 tpi
  • 3/8" x 10 tpi
  • 1/2" x 4 Skip
  • 1/2" x 6
  • 1/2" x 10 tpi
  1. Axcaliber Pack of 5 Bandsaw Blades - 2,490mm(98")
Total:
£136.52 £113.77
Axcaliber bandsaw blades are manufactured at Axminster using advanced CNC machining, high precision digital measuring equipment and specialised heat treatment facilities. Detailed quality checks are performed at each stage of manufacture using the most modern inspection equipment. The result is a blade which consistently cuts straighter, has harder, longer-life teeth and which gives a superior finish to the work. The final step in the manufacturing process is one of the most important - the weld. We have invested heavily in this area through the purchase of precision welding and grinding equipment and are, as a result, one of the few companies worldwide able to offer a fully guaranteed weld. Blades are cut accurately to length then, using an IDEAL bandsaw blade welder, a high voltage current is passed through the blade to achieve a precision butt weld. The weld is annealed to remove any brittleness and danger of fatigue and then hand dressed to produce a perfectly smooth joint.
British Made British Made
4.80 66
