PEANUT® 2 Connecting System Package
- Self-clamping invisible connectors, create an incredibly strong joint
- Quick and easy assembly or reassembly of cabinets
- Brilliant solution for making 90° and 45° joints
Customers Also Bought
The PEANUT®2 is a self-clamping invisible connector. The PEANUT® Connecting System is incredibly simple to use. This package includes the jig, cutters and connectors.
Making joints with the PEANUT® jig is quick and efficient, resulting in a strong, rigid connection. Anyone with a 1/2" router and a drill can produce a wide variety of cabinet joints quickly, with spot-on accuracy everytime; 90° and 45° joints. The PEANUT® 2 jig is just about as foolproof as a jig can be; with easy to follow instructions.
The connectors create secure, strong joints and enable furniture to be taken apart and reassembled many times without loss to the joint strength, making it ideal for flat-packing. In addition to the jig, the package includes the special PEANUT® router cutter (1/2” shank), 100 x PEANUT®2 connectors, a 6mm drill bit with depth stop and a 24mm low profile router guide bush. The only additional items required are clamps and 3.5mm size/gauge screws with the length of screw depending on material thickness. For board thickness 18 to 25mm.
- Use with hand-held router jig or CNC machines
- Cabinets can be shipped flat with connectors pre-inserted
