£1,295.98 £1,079.98
Out of stock
  • Cast iron frame for higher longevity and stability
  • Balanced aluminium wheels to avoid vibration
  • 2 speeds give a choice depending on the materials
Customers Also Bought
The Pégas® Scroll Bandsaw is a precision machine using Pégas scroll bandsaw blades, the finest and most accurate Swiss made blades ever produced. This unique development is dedicated to both hobbyists and professional users in the woodworking industry.
The heart of the machine is a specially developed roller guide system that is perfectly adapted to the Pégas scroll bandsaw blades. The guide consists of one roll bearing above and one roll bearing below the machine table that contains a guiding groove which is adapted to the respective fine cutting saw blade.
The top and bottom guides consist of a CNC-machined aluminium block and a special ball-bearing guide, featuring grooves along which the blade is guided above and beneath the table. The special tooth design avoids vibrations completely and provides for a high cutting performance with an incredible smooth finish of the edges. Such high-precision guiding allows for the sawing of very complex shapes, curves and radiuses. The ball-bearings (92.000-U) delivered with the machine feature two grooves of different dimensions, one being appropriate for blade #9 and the other for blade #12.
The bandsaw itself is a simple cast iron frame machine, with an anti-wear coating on the cast iron table. The table can tilt to 40° for bevels. It has two blade speeds, both are quite high as required by these special blades. For soft and hardwood with a thickness of up to 150 mm.
The machine is delivered with:
1 x #9 blade and 1 x #12 blade
Top and bottom Pégas precision blade guides, including appropriate ball-bearings for #9 and #12 blades
1 stand 580mm in height and with a base dimension of 525 x 575mm
LED light
  • Blade protection guard system for extra safety
  • A safety switch system prevents machine operation with open doors
  • The cast iron table, with a 40° tilting capability, is coated with a wearproof coating
  • The suction system is placed directly under the worktable in order to achieve optimal efficiency
Warranty 2 Year Warranty
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
