Pegas Regular Progressive Scroll Saw Blades
- Made in Switzerland from heat treated high carbon steel
- Perfect for faced materials or veneers, very clean internal cuts
- Fine entry teeth plus coarse centre teeth for waste clearance
- Blade length 130mm
- Pack of 12
Progressive tooth blades are versatile, performing well in wood, plastic, bone, Corian® and most fibrous materials. These blades feature fine entry teeth to avoid splitting or tear-out and have coarser teeth in the centre to clear the waste. Perfect for coated materials or veneered surfaces, they give a very clean internal cut. Thickness of work ranges from 1.5mm to 60mm. Overall blade length 130mm.
