Pegas Skip Tooth Scroll Saw Blades
AX877480
AX877480
- Heat treated high carbon steel
- Versatile, suitable for many materials
- Made in Switzerland
- Blade length 130mm
- Packs of 12
Show more
Show less
Skip tooth blades are versatile, performing well in wood, plastic, bone, Corian® and most fibrous materials. These blades provide excellent chip removal, accept a fast feed rate and give a smooth finish. The range of sizes and teeth per inch allows the cutting of intricate patterns as well as rough-cut work. Thickness of work ranges from 1.5mm to 60mm. Overall blade length 130mm.
Scroll Saw Blade Length | 130 mm |
