Perform PD216SMS Slide Mitre Saw 230V
113594
Special Price £112.49 £93.74 was £149.98 £124.98 Save £37.49 £31.24
  5. Half Star
3 Reviews
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Wednesday 12th Aug
  • Ideal entry-level or light use mitre saw
  • Forward‑facing bars save space when placed against a wall
  • 1,500W motor delivers smooth, accurate cuts
  • Shadow line shows exact cutting path
  • Mitres 0-47° both ways, bevels left 0-47°
  • 305mm cutting width with extension bed supports
  • Teflon coated 36T negative rake blade made by Axcaliber supplied
  • Dust bag and vacuum extraction port included
Perform PD216SMS Slide Mitre Saw; angles made easy
Take out the guesswork when it comes to cutting at an angle. The Perform PD216SMS Slide Mitre Saw is a versatile, entry level saw designed for light use, delivering excellent results for DIY or home workshop tasks.
Perform PD216MS Mitre Saw - space saving design
Space saving design
Forward-facing guide rails allow the saw to be positioned close to the wall, saving valuable workshop space.
Perform PD216MS Mitre Saw - cutting capacity
Cutting capacity
The saw boasts an impressive 80mm cutting depth and a 305mm width; plenty of capacity for your home projects or DIY tasks. The left and right hand pull-out extension bed supports longer lengths of timber when cutting.
Perform PD216MS Mitre Saw - secure clamping
Secure clamping
Securely hold timber in place using the material clamp to prevent movement and enhance safety.
Perfect accuracy
The mitre saw's light casts a precise shadow indicating where the cut will be made, making it easier to align and visualise.
Perform PD216MS Mitre Saw - cut at a range of angles
Cut at a range of angles
The saw accommodates mitre cuts 0° to 47° left and right, as well as bevel cuts to the left at 0° to 47°.
Perform PD216MS Mitre Saw - quality blade
Quality blade
Supplied with a 36 tooth Teflon coated contract quality blade from Axcaliber. This helps to prevent resin build up on the blade.
Perform PD216MS Mitre Saw - safeguard your health
Safeguard your health
Many mitre saws have poor extraction, but with this one there is a dust bag supplied, or you can connect your saw to a suitable vacuum extractor via the 38mm port.
Perform PD216MS Mitre Saw - ideal for decking, outdoor projects, cutting trim and mouldings and more
Perfect for...
Ideal for decking, outdoor projects, cutting trim and mouldings and more, it makes for a great beginner saw or for those using lightly.
Perform 216mm saw blade set
Browse the accessories...
This 216 mm saw blade set comprising a 36-tooth blade and a 56-tooth blade is ideal for smooth, precise, and safe cutting. Both blades feature a Teflon coating to reduce heat buildup and friction, ensuring cleaner cuts and extended blade life.
Not sure which machine is right for your task?
Explore our machinery classification page to compare classification options and ensure you select the best machine for your needs.
The Perform PD216SMS Slide Mitre Saw is a compact tool designed with cutting versatility and space saving in mind. Featuring a forward facing guide rail system, this saw can be positioned closer to the wall - ideal for workshops with limited floor space.
Equipped with a 1.4kW motor and a 216mm diameter blade, the PD216SMS delivers a blade speed of up to 5,000rpm, enabling smooth and precise cuts across a variety of materials. The Teflon-coated blade offers contract-grade performance straight out of the box.
This mitre saw supports a wide range of cutting angles, mitring from 0° to 47° in both directions and beveling to the left from 0° to 47°, making it suitable for a variety of angled cuts. Trenching cuts can be achieved by adjusting the depth stops. Achieve precise cuts with the mitre saw's shadow line, clearing indicating the exact cutting path for easy alignment. Use the clamp to securely hold the timber in place, preventing any movement and enhancing safety. With a generous cutting capacity of up to 305mm wide and 80mm deep, the saw also features left and right pull-out extension bed supports for handling longer lengths of timber.
To help keep your workspace clean, a dust bag is provided or there's a 38mm dust extraction outlet that you can connect to a vacuum extractor.
Ideal for tasks such as decking, trim, moulding, and other indoor or outdoor woodworking projects, this saw is perfect for beginners or as a reliable, light-duty addition to any workshop.
Warranty Perform 1 Year Warranty
Perform 1 Year Guarantee
With every Perform machine, you get our 1-year guarantee, which includes:
Complete machinery coverage (excluding blades, abrasives, belts, filters/bags, other consumables).
Machine Classifcation
These products are designed for light, occasional use. They must be maintained and serviced in line with our schedule and are not intended for continuous or high operation, otherwise guarantee may be void.
Find out more
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBirthday CakeA birthday cake with a candleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesChristmasChristmasClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPound SignA pound currency sign in a circlePreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSign InSign In to your accountSign OutSign Out of your accountSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.33 3
