Perform PD254TS 254mm Saw Bench 230V
113359
Special Price £188.98 £157.48 was £209.98 £174.98 Save £21.00 £17.50
  5. Half Star
12 Reviews
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Wednesday 2nd Sep
  • Compact design, ideal for beginners
  • Powerful 2kW motor
  • Soft-start for quieter operation
  • Supplied with a 24T and 60T blade
  • Includes a mitre fence and push stick
  • Efficient dust extraction
An excellent starter table saw with versatile cutting power
Perfect for beginners, the PD254TS Saw Bench is a fantastic first table saw. It’s designed to handle a variety of timber sizes and makes different types of cuts easy. With handy features like soft start, blade tilt, and cast aluminium tables, it’s a great choice for woodworking crafts, and all kinds of DIY projects.
PD254TS saw bench - strong and study
Strong and sturdy
The 560 x 680 mm strong coated cast aluminium table gives a solid space to work on and ensures for smooth cutting. The rigid table insert prevents collapsing when cutting.
Soft start
The soft start feature ensures that the motor powers up gradually, making the saw more user-friendly, especially in shared or residential environments.
Powerful motor
The high powered 2000W motor maintains blade speed for a consistent cut.
Mitre and rip fence included
The mitre fence allows you to produce accurate crosscuts at any angle. The dual locking rip fence ensures that it is super rigid for accurate cuts.
Cutting capacity
The saw boasts an impressive 80mm cutting depth and a 650mm width capacity, thanks to its extendable side table. This makes it easy to handle larger pieces of wood.
PD254TS saw bench - blade tilt
Blade tilt
The blade tilts from 90 to 45 degrees so you can achieve a range of different cuts including mitred, rip cuts and crosscuts in both man-made and natural timbers.
Quality blades
Two Teflon coated blades are included which help to prevent resin build-up; a 24-tooth ripping blade and a 60-tooth crosscut blade.
PD254TS saw bench - push stick
Push stick included
A push stick is included for safe working as well as integrated tool storage to save space.
Want some extra blades?
Buy our 254mm saw blade package.
The Perform PD254TS Saw Bench is a compact yet powerful solution for home workshops and DIY users. Its solid steel frame construction makes it easy to transport and store, perfect for those with smaller workspaces or mobile setups.
Despite it's compact size, the PD254TS is equipped with a 2kW motor that delivers smooth, consistent power for a wide range of tasks. A soft start feature ensures that motor powers up gradually, reducing noise while making the saw more user-friendly, especially in shared or residential environments.
This saw offers impressive cutting capacity, with a maximum depth of cut of 80mm at 90° and 50mm at 45°. The rip fence allows for up to 300mm of cutting width, which extends to 650mm with the side table extension. With the extensions fitted, the total table width reaches 1,025mm, providing excellent support for larger workpieces. The rip fence locks at the front and back making it super rigid for accurate cuts. The coated aluminium table includes 19mm T-slots on either side of the blade, allowing mitre fences and jigs to slide smoothly for precise, controlled cuts.
The tilt and height adjustment mechanism is bolted to the chassis as opposed to the underside of the table, for smooth operation.
Supplied with an adjustable mitre fence for angled cuts and a sturdy rip fence for straight, repeatable results, the PD254TS is well-equipped for a variety of woodworking tasks. A push stick is included for added safety and is housed within the integrated tool storage section. Two Teflon blades are included which help prevent resin build up; a 24 tooth ripping blade and a 60 tooth crosscut blade.
Dual 35mm dust extraction ports help to maintain a cleaner working environment when connected to a suitable dust extractor, and the fitted 230V plug means it's ready to go straight out of the box.
Warranty Perform 1 Year Warranty
Perform 1 Year Guarantee
With every Perform machine, you get our 1-year guarantee, which includes:
Complete machinery coverage (excluding blades, abrasives, belts, filters/bags, other consumables).
Machine Classifcation
These products are designed for light, occasional use. They must be maintained and serviced in line with our schedule and are not intended for continuous or high operation, otherwise guarantee may be void.
Find out more
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBirthday CakeA birthday cake with a candleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesChristmasChristmasClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPound SignA pound currency sign in a circlePreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSign InSign In to your accountSign OutSign Out of your accountSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.33 12
