Used with a power drill or flexible shaft, this kit provides all you need to produce a high gloss finish on wood. The kit contains everything needed to carry out the process in three easy stages. Firstly, an aluminium oxide lapping mop, followed by the 100mm firm mop and buff compound. Finally, for a high gloss finish the 100mm soft mop and buff compound. The fluted design improves airflow and reduces overheating for better continuous work.The kit also includes a straight arbor with which to mount the mops in a drill chuck. Ideal for preparation & denibbing, buffing and polishing to a mirror finish.
Mop Diameter 100 mm
EAN Barcode 5060030663373
