Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Powermatic 3520C Woodturning Lathe
Code: 105893
  • Versatile, superbly engineered woodturning lathe
  • Massive, vibration absorbing, cast iron with large capacities
  • Infinitely variable speed with digital display
  • Wide range of speeds from 15rpm to 3,200rpm
  • Moveable control box for convenience and safety
  • Extended spindle nose increased access to the workpiece
  • Large polished ergonomic cam-lock handles
  • Adjustable riser blocks for up to 150mm of height adjustment
  • Tailstock with 6tpi Acme threads for smooth operation
  • Digital indexing readout simplifies the indexing process
  • Show More
Save £684.00
NOW £3,605.00
Normally £4,289.00
(£3,004.17 Ex. VAT)
In stock - heavy goods delivery within 7-21 working days
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
Heavy Goods
  • UK mainland - free
  • UK remote - charge advised in basket
This bespoke service includes off-loading and assistance where practical. Our delivery experts will contact you to arrange a convenient delivery date.
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
Powermatic 2 Year Warranty
The Powermatic 3520C lathe is the flagship lathe from the USA’s top woodturning brand. Made almost entirely of cast iron with each part precision machined and ground to ensure smooth trouble-free movement. The headstock, tailstock and tool-rest banjo all have positive cam action locks with large polished handles. The headstock can slide up and down the entire length of the bed, which allows the turning of very large diameter work at the tailstock end of the lathe. There is provision for a bed extension with a choice of two positions.
The 3520C features electronic variable speed with low and high speed ranges driven via a 2-step, multi-groove poly-V belt for full power transmission. The control box houses the on/off buttons, speed control knob, forward/ reverse switch and digital display of both rpm and index position. The control box is removable from the headstock housing, which allows you to reposition it anywhere along the lathe bed for maximum convenience. Strong magnets within the box hold it in place. The indexing offers 48 positions (7.5° increments), the digital display helps keep track.
The tailstock quill has a laser-etched scale in metric and imperial. The quill is self-ejecting, and a 6tpi Acme thread makes movement fast and smooth. The 3520C comes with comparator centres for copy work with cast iron brackets, which fit onto the headstock and tailstock castings. The riser blocks ensure you can turn at the height you are most comfortable with; fitting the blocks adds an additional 100mm to 150mm. Other standard equipment includes 350mm tool rest, a sliding hammer knockout rod with brass tip, a drive centre and a live centre with removable cone, faceplate and spanner.
Promo
This product is on page 332 of the Axminster Tools & Machinery 2019/20 Catalogue.
Powermatic 3520c Lathe
Powermatic provide expert woodworkers with the tools and confidence to create and inspire!
1.5kW Motor
Effortlessly tackle large, unbalanced workpieces
Weighing 330kg and fitted with a powerful, 1.5kW motor, you’re able to take on even the largest projects.
Sliding Headstock
Convenient positioning for accurate turning
The sliding headstock and precision machined bed enable you to carry out small, precise projects.
Moveable Control Box
Quick start and stops
The moveable control box gives you the flexibility to set the lathe up into a position that most suits your work.
Digital Display
Makes turning a customisable and intuitive experience
The indexing has over 48 positions and is easy to keep track of using the digital display.
Specification
Specification
Distance Between Centres 910 mm
Headstock Taper 2 MT
Max Diameter over Bed 508 mm
Model 3520C
Nett Weight 330 kg
Overall L x W x H 1,765 mm x 930 mm x 1,190 mm
Power 1.5 kW
Rating Industrial
Spindle Thread M33 x 3.5 mm
Tailstock Taper 2 MT
Voltage 230 V
Lathe Speed 15 - 1,200 / 40 - 3,200 rpm (var)
Tool Post Diameter 25.4 mm (1")
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
