For our latest updates about delivery and stores, click here
From £2,799.96 £2,333.30 was £3,099.00 Save £299.04
  • Top quality bandsaw for busy professional workshops
  • 370mm throat and 355mm capacity
  • Generous, ground cast iron table with -10° to +45° tilt
Customers Also Bought
The Powermatic PM1500 bandsaw built for a busy workshop where performance and quality are priorities.
A 2.2kW motor drives balanced, heavy cast iron wheels via a poly-vee drive belt for smooth running. The PM1500 has a large re-saw capacity of 350mm under the guides and a throat capacity of 370mm. The upper blade guide moves easily on rack-and-pinion mechanism. Upper and lower blade guides are large and easily adjustable without the need for tools.
The PM1500 comes with Powermatic’s patented Accu-Fence. This 155mm tall, extruded aluminium fence is easy and quick to switch to the lower position (12mm) when cutting thinner work. Replacing the fence with the 36mm diameter steel pin gives you a single point contact for cutting to a line, steering veneers or for curved work. Sturdy cast-iron trunnions support a generous precision ground table. The table tilts from -10° to +45°.
The PM1500 features a magnetic NVR switch with interlocking switches on both doors, which prevent the machine from starting on with the doors open. A unique safety feature is a cutout switch on the blade-tensioning lever; preventing the saw from powering up when the blade is un-tensioned. This eliminates the risk of the blade jumping off the wheels when it’s loose.
The PM1500 has two dust ports, positioned to extract the maximum amount of debris and prevent sawdust building-up inside the machine. Cleaning brushes in the lower cabinet ensure even smoother running, one sweeps the blade clean while the other sweeps the tyre clean.
The fit and finish of the PM1500 is immaculate. The paintwork is excellent inside and out and the chromed hand wheels and knobs exude quality.
  • Patented Accu-Fence maximises accuracy and safety
  • Fence plate can be used in the horizontal or vertical position
  • Electrical interlock prevents start up if blade not tensioned
  • Blade guides with tool-less adjustment
  • Solid cast iron wheels add momentum for heavy resaw
  • Superb Powermatic build quality
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolYouTubeThe logo for YouTube
