Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Powermatic PM2244 Drum Sander
Code: 102303
  • LED control panel shows major machine functions
  • Equipped with Feed Logic, produces exceptional finish
  • Table parallelism is adjusted with a simple dial
  • Drum carriage provides strength and consistent performance
  • Belt tracking reduces the need for manual adjustment
  • Precision-machined conveyor bed provides a flat sanding surface
  • Closed stand with storage for keeping abrasives organised
  • Show More
£2,499.00 (£2,082.50 Ex. VAT)
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
Heavy Goods
  • UK mainland - free
  • UK remote - charge advised in basket
This bespoke service includes off-loading and assistance where practical. Our delivery experts will contact you to arrange a convenient delivery date.
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
Powermatic 2 Year Warranty
Packed full of innovation and real life design features that work, this drum finishing sander has to be at the top of the list.
N.B. These sanders are used for fine finishing, they are not intended to be used as a thicknesser or with coarse abrasive for significant stock removal. In all instances, they are intended to be used with planed and thicknessed material.
As with all Powermatic machines, this machine is very well made, cast iron where it matters and cast alloy for the intricate parts. One design feature that really helps is the LED control panel. This gives real time information on conveyor feed speed, sanding work load and drum height. The patented Feed Logic system prevents overloading the machine and enhances the finish.
On a single arm machine such as this, making sure that the arm is parallel to the sanding conveyor is paramount. Adjustment of this is such an easy task that it will become second nature, improving your work.
Changing abrasives is also made easy, thanks to easy access to the securing clips. The conveyor belt is pulled, which evens the load, and is spring tensioned and fitted with a tracking device to keep the belt centred. Standard extension tables are made from thick gauge sheet steel to resist flexing. There is a heavily built guide system to control the drum height, with hardened slideways and an adjustable jib strip to control the smoothness of movement. The one-piece steel cabinet has a handy storage cupboard, and is fitted with wheels for mobility. A single 100mm dust extraction outlet is provided, efficient dust extraction is vital with these machines, please make sure your system is adequate. Minimum sanding length only 60mm.
This machine has world class design features, giving usability and sophistication that is unmatched.
Promo
This product is on page 73 of the Axminster Tools & Machinery 2019/20 Catalogue.
Powermatic
What makes Powermatic the Gold Standard?
With over 90 years of experience in the industry, Powermatic build machines that push the limits of engineering and design to allow you to expand your creative ability. With this in mind, they look to guarantee that their machinery is at the forefront of industrial machinery in each of the following areas.
Heavy duty construction
With their cast iron and welded steel machines, it’s plain to see why Powermatic is renowned for their heavy duty construction. The superb build quality gives the machines strength and rigidity but also provides a stable platform to complete accurate work.
Forward thinking innovation
From the Accu-Fence® on the bandsaw to the Feed Logic on the drum sander, Powermatic continues to innovate new and unique ideas that are all designed not only to improve your work but also increase safety and ease of use.
Attention to detail
Attention to detail
No stone has been left unturned on a Powermatic machine. The chromed handwheels and immaculate paintwork exude quality. Furthermore, the comparator centres on the lathes and integrated castors on the PM 22-44 show you that everything has been thought of. Where other competitors may ‘cut corners’ in certain areas, you can be guaranteed that Powermatic have not.
High performance
High performance
Powermatic build machines with large capacity, high-performance motors equipped to deal with the most demanding woodworking tasks. If you’re looking for something that will push the boundaries of your work and get the most of your abilities, you can’t look past a Powermatic.
Specification
Specification
Abrasive Roll Width 76 mm
Dust Extraction Outlet 100 mm
Feed Speed 0 to 3 m/min (var)
Model PM2244
Nett Weight 149 kg
Overall L x W x H 1,073 mm x 957 mm x 1,257 mm
Power 1.3 kW
Rating Industrial
Sanding Drum Diameter 127 mm
Sanding Thickness Min\Max 0.8 mm to 100 mm
Sanding Width Double Pass 1,120 mm
Sanding Width Single Pass 560 mm
Sound Power Level [Uncertainty K] 76 dB(A)
Table Size 590 mm x 385 mm
Voltage 230 V
Drum Speed 1,400 rpm
Min Extraction Airflow Required 1,000 m³/hr
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
