Pro-Fit Plinth Lock patented plinth lock system is a unique way of firmly securing kitchen plinths as well as many other applications.
This concealed fixing is quick and easy to fit. Using Pro-Fit Plinth Lock ensures a 90° solid looking joint without unsightly gaps and eliminates the need for external screw fixings.
Fitting couldn’t be easier, simply line up and screw the Pro Lock female half onto the end panel and the male onto the plinth. Push the plinth into position; Pro Lock holds the end joints tightly together while standard leg clips secure the plinth. Pro Lock has many other uses; there is provision for inserting a locking screw between the two halves for a more permanent fixing.
Supplied in a pack of 6.
Unique, firmly secures 90° kitchen plinth joints
Concealed fixing that is quick and easy to fit
Eliminates unsightly gaps between plinths and end panels
Plinth joints are permanently neat and close fitting
