Penn State Industries
3 in 1 Pizza Cutter, Slicer & Server
SKU: 110896
£16.58
£13.82 Excl. VAT
  • 3 in 1 pizza cutter and server
  • Serrated edge and rolling cutter
  • Stainless Steel, food safe and rustproof
Cut and serve your pizza with ease, with this handy 3 in 1 pizza cutter. Features a serrated edge for slicing as well as a razor-sharp rolling wheel for tackling crusts. The wide, flat platform lets you easily serve up slice, after slice, after slice. Stainless Steel construction makes this 3 in 1 cutter food safe, rust resistant and simple to clean. Easy to make on a 7mm mandrel or turn between centres.
Difficulty Beginner
Drill Bit Required 15/32
Minimum Blank Size 1-1/2” x 1-1/2” x 4”
Web Attribute Set Project Kits
