{"product_id":"amana-spiral-down-cut-plastic-cutting-router-cutters","title":"Amana Spiral Down Cut Plastic Cutting Router Cutters","description":"\u003cp\u003eThese spiral 'O' flute router bits are ideal for industrial applications and are manufactured to produce optimum results on every cut, especially when cutting acrylic materials and plastics. Made from high quality carbide, they feature a polished \u003cspecial id=\"32\"\u003e\u003c\/special\u003emirror finish\u003cspecial id=\"32\"\u003e\u003c\/special\u003e cutting edge. This means a cleaner cut, reduced risk of chip re-welding, extended tool life and dissipates heat well to prevent melting. Left hand helix left hand cut.\u003c\/p\u003e\u003cp\u003eThese router bits can be used to cut the following materials:\u003c\/p\u003e\u003cp\u003ePlastic\/Acrylic\u003c\/p\u003e\u003cp\u003eAcetal and Nylon\u003c\/p\u003e\u003cp\u003eAcrylic Stone\u003c\/p\u003e\u003cp\u003eAcrylonitrile Butadiene Styrene (ABS)\u003c\/p\u003e\u003cp\u003eAluminum Composite Material (ACM)\u003c\/p\u003e\u003cp\u003eAlupanel®\u003c\/p\u003e\u003cp\u003eCorian\u003c\/p\u003e\u003cp\u003eCoroplast®\u003c\/p\u003e\u003cp\u003eCorrugated Plastics such as Correx Boards and Polypropylene\u003c\/p\u003e\u003cp\u003eCrosslinked Polyethylene (XPE, PEX, XLPE)\u003c\/p\u003e\u003cp\u003eDelrin\u003c\/p\u003e\u003cp\u003eDibond®\u003c\/p\u003e\u003cp\u003eExtruded Acrylic\u003c\/p\u003e\u003cp\u003eFoam Board\u003c\/p\u003e\u003cp\u003eFomex®\u003c\/p\u003e\u003cp\u003eGatorfoam®\u003c\/p\u003e\u003cp\u003eHard Plastic\u003c\/p\u003e\u003cp\u003eHigh Density Polyethylene (HDPE)\u003c\/p\u003e\u003cp\u003eHigh Density Urethane (HDU Board)\u003c\/p\u003e\u003cp\u003eHigh Impact Polystyrene (HIPS)\u003c\/p\u003e\u003cp\u003eHigh Impact Polystyrene (HIPS) for digital printing\u003c\/p\u003e\u003cp\u003eHigh Pressure Laminates (HPL)\u003c\/p\u003e\u003cp\u003eHydroxy-Terminated Polyether (HTPE)\u003c\/p\u003e\u003cp\u003eKing ColorCore® The Multi-Color Engravable Polymer Sheet.\u003c\/p\u003e\u003cp\u003eLaminate\u003c\/p\u003e\u003cp\u003eLow Density Polyethylene (LDPE)\u003c\/p\u003e\u003cp\u003eLubX®\u003c\/p\u003e\u003cp\u003eLucite®\u003c\/p\u003e\u003cp\u003eMechanical\/Engineered Plastics\u003c\/p\u003e\u003cp\u003ePerspex® Cast Acrylic Sheet\u003c\/p\u003e\u003cp\u003ePlexiglas®\u003c\/p\u003e\u003cp\u003ePoly (methyl methacrylate) (PMMA)\u003c\/p\u003e\u003cp\u003ePolycarbonate (Lexan™)†\u003c\/p\u003e\u003cp\u003ePolyethylene Terephthalate Glycol-Modified (PETG \/ PET-G)\u003c\/p\u003e\u003cp\u003ePolyoxymethylene (POM), also known as Acetal, Polyacetal and Polyformaldehyde.\u003c\/p\u003e\u003cp\u003ePolystyrene (PS)\u003c\/p\u003e\u003cp\u003ePVC\u003c\/p\u003e\u003cp\u003eSign Foam\u003c\/p\u003e\u003cp\u003eSintra PVC\u003c\/p\u003e\u003cp\u003eSolid Surface\u003c\/p\u003e\u003cp\u003eStarBoard® (King StarBoard 'R') High Density Polyethylene Sheet (HDPE)\u003c\/p\u003e\u003cp\u003eTeflon®\u003c\/p\u003e\u003cp\u003eThermoplastic Polyolefin (TPO)\u003c\/p\u003e\u003cp\u003eTrespa® Meteon®\u003c\/p\u003e\u003cp\u003eUltra High Molecular Weight Polyethylene (UHMWPE)\u003c\/p\u003e\u003cp\u003eUrethane\u003c\/p\u003e\u003cp\u003eVinyl Flooring\u003c\/p\u003e\u003cp\u003eWood\u003c\/p\u003e\u003cp\u003eSuitable for use with CNC Routers and shouldn't be used with a handheld router.\u003c\/p\u003e","brand":"Amana Tool","offers":[{"title":"3.2 mm (1\/8\") \/ 1\/8\" (3.2 mm )","offer_id":54161086382427,"sku":"111597","price":6.59,"currency_code":"GBP","in_stock":true},{"title":"3.2 mm (1\/8\") \/ 1\/4\" (6.35 mm)","offer_id":54161086415195,"sku":"111599","price":8.05,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/111597_xl.jpg?v=1790092841","url":"https:\/\/www.axminstertools.com\/products\/amana-spiral-down-cut-plastic-cutting-router-cutters","provider":"Axminster Tools","version":"1.0","type":"link"}
