{"product_id":"amana-spiral-upcut-aluminum-cutting-router-cutters-zrn-coated","title":"Amana Spiral Upcut Aluminum Cutting Router Cutters ZrN Coated","description":"These spiral 'O' flute router bits are ideal for industrial applications and are manufactured to produce optimum results on every cut, and should help make aluminium projects less labor-intensive. Made from the highest quality sub-micrograin carbide, they feature a polished \u003cspecial id=\"32\"\u003e\u003c\/special\u003emirror finish\u003cspecial id=\"32\"\u003e\u003c\/special\u003e cutting edge. This means a cleaner cut, reduced risk of chip re-welding, superior surface finish, and extended tool life. Right hand helix right hand cut.  These router bits can be used to cut the following materials: ALPOLIC® Copper Composite Material (CCM) Alucobond® Aluminum Aluminum 5052 Aluminum 6061 Aluminum Alloys Aluminum Composite Materials (ACM) Aluminum Composite Panel (ACP) Alupanel® Brass Copper Dibond® Durabond e-panel™ Etalbond® Fomex® with Aluminum Face Gold Non-Ferrous Metals Plastic Silver Solid Surface Titanium Composite Material (TCM) Wood  These cutters feature a Zirconium Nitride (ZrN) coating, which offers these benefits:  \u003cspecial id=\"14\"\u003e\u003c\/special\u003e A harder and tougher cutting edge, leading to increased life of the cutting edge and reduced build up in the flutes during cutting.  \u003cspecial id=\"14\"\u003e\u003c\/special\u003e Increased spinning rate compared to an uncoated tool.   \u003cspecial id=\"14\"\u003e\u003c\/special\u003e A low Total Indicated Runout (TIR) and optimized flute geometry: resulting in clean cuts and reduced chatter under high chip loads, and virtually eliminate sanding.  \u003cspecial id=\"14\"\u003e\u003c\/special\u003e High flute volume supporting high feed rates and chip loads.  \u003cspecial id=\"14\"\u003e\u003c\/special\u003e High aspect ratio for single pass deep-reach cutting.  Suitable for use with CNC Routers and shouldn't be used with a handheld router. Do not cut ferrous metals with these bits. It's recommended to use mist lubricant system or air cooling for best results and extended tool life.","brand":"Amana Tool","offers":[{"title":"3.2 mm (1\/8\") \/ 12.7 mm (1\/2\") \/ 2","offer_id":54161089233243,"sku":"111644","price":10.44,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/111625_xl.jpg?v=1790092870","url":"https:\/\/www.axminstertools.com\/products\/amana-spiral-upcut-aluminum-cutting-router-cutters-zrn-coated","provider":"Axminster Tools","version":"1.0","type":"link"}
