{"product_id":"amana-spiral-upcut-aluminum-cutting-router-cutters","title":"Amana Spiral Upcut Aluminum Cutting Router Cutters","description":"\u003cp\u003eThese spiral 'O' flute router bits are ideal for industrial applications and are manufactured to produce optimum results on every cut, and should help make aluminium projects less labor-intensive. Made from the highest quality sub-micrograin carbide, they feature a polished \u003cspecial id=\"32\"\u003e\u003c\/special\u003emirror finish\u003cspecial id=\"32\"\u003e\u003c\/special\u003e cutting edge. This means a cleaner cut, reduced risk of chip re-welding, superior surface finish, and extended tool life. Right hand helix right hand cut.\u003c\/p\u003e\u003cp\u003eThese router bits can be used to cut the following materials:\u003c\/p\u003e\u003cp\u003eALPOLIC® Copper Composite\u003c\/p\u003e\u003cp\u003eMaterial (CCM)\u003c\/p\u003e\u003cp\u003eAlucobond®\u003c\/p\u003e\u003cp\u003eAluminum\u003c\/p\u003e\u003cp\u003eAluminum 5052\u003c\/p\u003e\u003cp\u003eAluminum 6061\u003c\/p\u003e\u003cp\u003eAluminum Alloys\u003c\/p\u003e\u003cp\u003eAluminum Composite\u003c\/p\u003e\u003cp\u003eMaterials (ACM)\u003c\/p\u003e\u003cp\u003eAluminum Composite Panel (ACP)\u003c\/p\u003e\u003cp\u003eAlupanel®\u003c\/p\u003e\u003cp\u003eBrass\u003c\/p\u003e\u003cp\u003eCopper\u003c\/p\u003e\u003cp\u003eDibond®\u003c\/p\u003e\u003cp\u003eDurabond\u003c\/p\u003e\u003cp\u003ee-panel™\u003c\/p\u003e\u003cp\u003eEtalbond®\u003c\/p\u003e\u003cp\u003eFomex® with Aluminum Face\u003c\/p\u003e\u003cp\u003eGold\u003c\/p\u003e\u003cp\u003eNon-Ferrous Metals\u003c\/p\u003e\u003cp\u003ePlastic\u003c\/p\u003e\u003cp\u003eSilver\u003c\/p\u003e\u003cp\u003eSolid Surface\u003c\/p\u003e\u003cp\u003eTitanium Composite Material (TCM)\u003c\/p\u003e\u003cp\u003eWood\u003c\/p\u003e\u003cp\u003eSuitable for use with CNC Routers and shouldn't be used with a handheld router. Do not cut ferrous metals with these bits. It's recommended to use mist lubricant system or air cooling for best results and extended tool life.\u003c\/p\u003e","brand":"Amana Tool","offers":[{"title":"6.35 mm (1\/4\") \/ 9.5 mm (3\/8\") \/ 2","offer_id":54161087791451,"sku":"111621","price":7.66,"currency_code":"GBP","in_stock":true},{"title":"4.76 mm (3\/16\") \/ 12.7 mm (1\/2\") \/ 2","offer_id":54161087824219,"sku":"111623","price":4.2,"currency_code":"GBP","in_stock":true},{"title":"4.76 mm (3\/16\") \/ 15.88 mm (5\/8\") \/ 2","offer_id":54161087856987,"sku":"111624","price":9.06,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/111619_xl.jpg?v=1790092862","url":"https:\/\/www.axminstertools.com\/products\/amana-spiral-upcut-aluminum-cutting-router-cutters","provider":"Axminster Tools","version":"1.0","type":"link"}
