Amana Tool
Amana Spiral Upcut Aluminum Cutting Router Cutters
SKU: 111621
£7.66 £32.38 Save £24.72
£6.38 Excl. VAT
  • Spiral 'O' flute
  • Highest quality carbide
  • Suitable for a range of materials
  • Mirror finish cutting edge
These spiral 'O' flute router bits are ideal for industrial applications and are manufactured to produce optimum results on every cut, and should help make aluminium projects less labor-intensive. Made from the highest quality sub-micrograin carbide, they feature a polished mirror finish cutting edge. This means a cleaner cut, reduced risk of chip re-welding, superior surface finish, and extended tool life. Right hand helix right hand cut.
These router bits can be used to cut the following materials:
ALPOLIC® Copper Composite
Material (CCM)
Alucobond®
Aluminum
Aluminum 5052
Aluminum 6061
Aluminum Alloys
Aluminum Composite
Materials (ACM)
Aluminum Composite Panel (ACP)
Alupanel®
Brass
Copper
Dibond®
Durabond
e-panel™
Etalbond®
Fomex® with Aluminum Face
Gold
Non-Ferrous Metals
Plastic
Silver
Solid Surface
Titanium Composite Material (TCM)
Wood
Suitable for use with CNC Routers and shouldn't be used with a handheld router. Do not cut ferrous metals with these bits. It's recommended to use mist lubricant system or air cooling for best results and extended tool life.
Overall Length 2
Shank Diameter 1/4" (6.35 mm)
X = Depth of Cut 9.5 mm (3/8")
D = Overall Diameter 6.35 mm (1/4")
