Arbortech
Arbortech HD Abrasive Discs 50mm (Pkt 20)
SKU: 105080
€16,00
  • For Arbortech Contour Sander, Mini TURBO Plane Kit, Mini Carver
  • Designed for premium performance when power sanding
  • Exceptionally long life, wide range of grits
  • Cloth-backed abrasive unaffected by heat
These 50mm diameters, sanding discs extend the scope of the Arbortech Contour Sander, Arbortech Mini TURBO Plane Kit and the Mini Carver.
They are heavy-duty to withstand harsh conditions when power sanding. The cloth-backed abrasive, unaffected by heat generated during power sanding, has an exceptionally long life.
Supplied in packs of 20 discs of a single grit, ranging from coarse 60 grit to extra fine 320 grit.
Additional Accessories No
Pack Quantity 20
Abrasive Grit 240
EAN Barcode 9313478020137
