{"product_id":"arbortech-mini-turbo-plane-kit-turbo-plane-blade","title":"Arbortech Mini TURBO Plane Kit \u0026 TURBO Plane Blade","description":"\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003ePackage comprises an Arbortech Mini TURBO Plane Kit and an Arbortech TURBO Plane Blade.\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003eArbortech Mini TURBO Plane Kit\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003eThe Arbortech Mini TURBO\u003cspecial id=\"10\"\u003e\u003c\/special\u003e kit is a revolution in wood sculpting. This unique tool fits the Arbortech Power Carving Unit and most 100mm or 115mm angle grinders using the supplied extension adaptor and the Arbortech Mini Carver\u003cspecial id=\"10\"\u003e\u003c\/special\u003e. This unique tool is great to use freehand or with guides and templates for accurate repeatable shaping. The compact 50mm blade and 62mm long extension can reach into tight spaces. The precision machined, mini blade has two solid tungsten carbide teeth. These cutting teeth are rotatable, resharpenable and replaceable.  The sanding discs and backing pad included with the kit allow final shaping, smoothing and finishing.\u003c\/p\u003e\u003cp\u003eThe comprehensive kit includes the Mini TURBO\u003cspecial id=\"10\"\u003e\u003c\/special\u003e blade, extension adaptor, 3 assorted sanding discs, a rubber backing pad, M5 fixing screws and washers plus Torx and hex drive keys.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003eArbortech TURBO Plane Blade\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003eUsing this 100mm blade is just like adding a rotary plane to your angle grinder. It removes stock very quickly and leaves a great finish. You can use it on green or seasoned timber. The 3 durable tungsten carbide blades hold their edge for a long time, and a quick whiz with a diamond file quickly restores the edge. The 100mm diameter blade fits the Arbortech Power Carving Unit and most 100mm(4\") and 115mm(4.1\/2\") angle grinders.\u003c\/p\u003e","brand":"Arbortech","offers":[{"title":"Default Title","offer_id":54227443122523,"sku":"720603","price":229.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/720603_xl.jpg?v=1790851630","url":"https:\/\/www.axminstertools.com\/products\/arbortech-mini-turbo-plane-kit-turbo-plane-blade","provider":"Axminster Tools","version":"1.0","type":"link"}
