This cutter head is designed to accurately cut rebates either from the top or bottom of the block. It has two vertical knives and four shear blades with four edges per blade. Also very useful for edge planing boards, battens and mouldings. Maximum rebate depth 20mm. Suitable for manual feed (MAN). Cutting diameter 100mm, height 30mm, bore 30mm.
Axcaliber
Axcaliber 2 Knife Rebate Block
| Bore Size | 30 mm |
| EAN Barcode | 5052511106011 |
