Axcaliber
Axcaliber 60 Degree Vee Groove Cutter
SKU: 506657
£19.98
£16.65 Excl. VAT
  • 60° vee groove cutter
  • Supplied with bearing to work with template
  • Can be used free hand
  • Sign writing, grooves in panels etc
  • Supplied in storage case
A 60 vee groove cutter, supplied with bearing to follow a template or use free hand. Uses include sign writing and producing grooves in panels. Two flute TCT cutter with 1/4 shank. Supplied in storage case.
Shank Diameter 1/4" (6.35 mm)
X = Depth of Cut 13 mm
D = Overall Diameter 12.7 mm (1/2")
K = Cutter Angle 60°
Web Attribute Set Chamfer, Engraving & V-Groove Router Cutters D: 12.7 X: 13
EAN Barcode 5052511063291
