Axcaliber
Axcaliber Bearing Guided Chamfer Cutters
SKU: 666158
£19.98
£16.65 Excl. VAT
  • Chamfer edges on straight or curved workpieces
  • Produces even, decorative chamfers on furniture
  • Slight chamfer prevents corners chipping on laminated boards
  • Precision made on multi axis CNC machines
  • High shear-cut angle for cleaner finish
  • Thick PTFE coating helps cutter to remain free of resin
One of the most useful cutters to have in your collection, the 45 chamfer cutters are excellent for just removing the sharp edges from your joinery work or making a wider more defined chamfer. Bearing guided cutters are an asset for curved work, as the cutter will follow the shape of the workpiece.
Shank Diameter 1/4" (6.35 mm)
X = Depth of Cut 11 mm (7/16")
D = Overall Diameter 30 mm (1.3/16")
K = Cutter Angle 45°
Web Attribute Set Chamfer, Engraving & V-Groove Router Cutters D: 30 X: 11
EAN Barcode 5052511030101
