A range of two-flute bevel cutters available in three different angles: 15, 22.5 or 30. For applying a bevelled edge to thicker timbers or used for jointing, boxes or multi-sided containers. A 15 bevel will produce a design with 12 sides, 22.5 bevel 8 sides and 30 bevel 6 sides. 1/2 shank. Supplied in storage cases.
Shank Diameter 1/2" (12.7 mm)
X = Depth of Cut 22.2 mm (7/8")
D = Overall Diameter 25 mm
K = Cutter Angle 15°
Web Attribute Set Chamfer, Engraving & V-Groove Router Cutters D: 25 X: 22.2
EAN Barcode 5052511063321
