Axcaliber
Axcaliber Bevel Panel Raising Cutter
SKU: 666208
£53.98
£44.98 Excl. VAT
  • Produces an attractive 16 bevel on raised panel edges
  • Bearing guided, suitable for use on curved head panels
  • Maximum speed of 12,000 rpm
  • Precision made on multi axis CNC machines
  • High shear-cut angle for cleaner finish
  • PTFE coating helps cutter to remain free of resin
  • This cutter is for use in router tables only
A wide bevel style panel raising cutter for use only in a router table with a maximum speed of 12,000 rpm. The cutter is bearing guided and is suitable for use on curved head panels. Please note this cutter is for use in router tables only.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
Shank Diameter 1/2" (12.7 mm)
X = Depth of Cut 16 mm (5/8")
D = Overall Diameter 76 mm (3")
H = Horizontal Depth of Cut 31.75 mm (1.1/4") Web Attribute Set: Thumb & Panel Moulding Router Cutters D: 76 H: 31.75 X: 16
EAN Barcode 5052511030545
