Designed for reliable cutting, these Axcaliber High Carbon Bandsaw Blades are a versatile choice for general purpose, workshop use. They're fit for all of those everyday tasks in the workshop where a smooth, good quality cut is required. Suitable for a wide range of materials, they can be used on wood, plywood, composition board, cork and plastic.
Made in the UK and manufactured from a single piece of high carbon steel, each blade features individually hardened tooth tips for smooth, clean cutting performance. High carbon blades are also more fatigue resistant than carbon hard back blades, making them well suited to regular general purpose applications.
Available in a wide range of lengths, blade widths and tooth configurations, simply choose the correct blade to fit your machine.
Bandsaw Blade Length 1,950 mm (77")
Bandsaw Blade Width 6.35 mm (1/4)
Bandsaw Blade Tpi 6
Web Attribute Set Bandsaw Blades
EAN Barcode 5052511006458
