Axcaliber
Axcaliber Contract 184mm TCT Saw Blades
SKU: 610491
£10.73
£8.94 Excl. VAT
  • Generously sized tips brazed onto tensioned quality steel plates
  • Covering rip to fine crosscut
  • 2.2mm kerf , 1.6mm plate
  • 16 bore
  • Perfect for mains powered circular saws
The Axcaliber range of Contract TCT (Tungsten Carbide Tipped) circular saw blades offers an unmatched blend of choice, cutting performance and price.
Manufactured in one of the most advanced facilities in the world, they are produced to the highest standards using the finest materials available. With the range covering everything from hand held power tools right up to large panel saws used in production workshops, you will be certain to find
a blade to suit every requirement. For other saw blades in the Axcaliber range see the Woodworking Machinery section.
Blade Diameter 184 mm
Maximum RPM 9,500 rpm
Kerf 2.2 mm
Teeth 24
Tooth Format ATB
Plate Thickness 1.6 mm
Hook Angle 18
Bore Size 16 mm
Blade Application Rip (24 teeth)
Web Attribute Set Circular Saw Blades
EAN Barcode 5052511000067
