The Axcaliber range of Contract TCT (Tungsten Carbide Tipped) circular saw blades offers an unmatched blend of choice, cutting performance and price.
Manufactured in one of the most advanced facilities in the world, they are produced to the highest standards using the finest materials available. With the range covering everything from hand held power tools right up to large panel saws used in production workshops, you will be certain to find
a blade to suit every requirement. 30mm bore. For all other blades please refer to the Woodworking Machinery section.
Blade Diameter 190 mm
Maximum RPM 9,000 rpm
Kerf 2.2 mm
Teeth 40
Tooth Format ATB
Plate Thickness 1.6 mm
Hook Angle 18
Bore Size 30 mm
Blade Application General Purpose (40 teeth)
Web Attribute Set Circular Saw Blades
EAN Barcode 5052511000128
