The Axcaliber range of Contract TCT (Tungsten Carbide Tipped) circular saw blades offers an unmatched blend of choice, cutting performance and price.
These 305mm diameter TCT tipped saw blades have sharp cutting point and edges for a better cut quality without chipping or splinters. Generally used for cutting natural timber, plywood, veneer or hardboard. Engineered with tensioned, ground plates, featuring laser-cut anti-vibration expansion slots to ensure smooth, stable operation. The cutting edges are formed from fine, micro grain tungsten carbide tips, which are CNC brazed and automatically ground to a razor-sharp finish, delivering clean, accurate cuts even in demanding applications. They feature a 2.2mm plate, 3.1mm kerf and 30mm bore (a range of bore reducing bushes are available).
Available in 3 tooth formats: 24T ripping blade, 40T general purpose and 72T for finer cross cuts.
