{"product_id":"axcaliber-contract-tct-saw-blade-254mm-x-2-1mm-x-60t-neg","title":"Axcaliber Contract TCT Saw Blade 254mm x 2.1mm x 60T Neg","description":"\u003cp\u003eThe Axcaliber Contract TCT Saw Blade range is designed to deliver reliable performance, clean results and excellent value for both trade and home workshop use. Manufactured in a state‑of‑the‑art European facility, each blade is produced to strict tolerances using high‑grade steel and precision‑ground tungsten carbide tips, ensuring consistent cutting quality and long service life.\u003c\/p\u003e\u003cp\u003eThis 254mm blade features a 2.1mm thin kerf, allowing it to cut efficiently with reduced resistance. The narrower kerf requires less power, making it particularly effective on mitre saws and smaller bench saws where maintaining smooth, controlled cuts is essential. The 60‑tooth configuration combined with a negative rake angle offers excellent control when cutting cross grain, sheet materials, and composite boards, providing a clean, accurate finish with reduced breakout.\u003c\/p\u003e\u003cp\u003eDesigned for dependable everyday use, the blade offers a balanced blend of durability and precision, making it a versatile option for workshops seeking consistent performance without compromise. Before installing, ensure your saw’s riving knife is compatible with thin‑kerf blades.\u003c\/p\u003e\u003cp\u003eThe blade is supplied with a fixed bore size suited to machines built for 254mm blades, and like all thin‑kerf designs, it is not suitable for use with bore‑reducing bushes.\u003c\/p\u003e\u003cp\u003eAchieve clean, dependable cutting performance with the Axcaliber Contract TCT Saw Blade - engineered for accuracy, efficiency, and long‑term reliability.\u003c\/p\u003e","brand":"Axcaliber","offers":[{"title":"Default Title","offer_id":54118784762203,"sku":"113580","price":22.48,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113580_xl.jpg?v=1789791937","url":"https:\/\/www.axminstertools.com\/products\/axcaliber-contract-tct-saw-blade-254mm-x-2-1mm-x-60t-neg","provider":"Axminster Tools","version":"1.0","type":"link"}
