The Axcaliber range of Contract TCT (Tungsten Carbide Tipped) circular saw blades offers an unmatched blend of choice, cutting performance and price.
Manufactured in one of the most advanced facilities in the world, they are produced to the highest standards using the finest materials available. With the range covering everything from hand held power tools right up to large panel saws used in production workshops, you will be certain to find
a blade to suit every requirement. Bore size 30mm. A range of bore reducing bushes are available. Perfect for the Festool mitre saws.
Blade Diameter 260 mm
Maximum RPM 7,600 rpm
Kerf 2.8 mm
Teeth 60
Tooth Format ATB
Plate Thickness 1.8 mm
Hook Angle 15
Bore Size 30 mm
Blade Application Fine (60 teeth)
Web Attribute Set Circular Saw Blades
EAN Barcode 5052511000340
