Designed for a first class result in all natural timbers and man-made boards, these blades are the perfect choice for professional use.
They are particularly suitable for cordless circular saws. The thin 1.5mm kerf is 33% less than similar standard blades. They require less energy from your battery for a given cut resulting in longer runtimes and less strain on your machine. The alternate top bevel (ATB) grind gives you rapid progress through the cut and a quality finish. Axcaliber Cutpro circular saw blades use the latest production techniques and the finest materials. The blades feature micro-grained TCT tips. The laser-cut plates substantially reduce noise while cutting. A faint tensioning ring halfway across the plate indicates where each individual blade undergoes a pre-stressing to guarantee smooth running.
The bore size is 20mm.
Blade Diameter 165 mm
Maximum RPM 9,000 rpm
Additional Accessories No
Kerf 1.5 mm
Teeth 52
Tooth Format ATB
Plate Thickness 1.0 mm
Hook Angle 18
Bore Size 20 mm
Blade Application Extra Fine (52 teeth)
Web Attribute Set Circular Saw Blades
EAN Barcode 5052511097739
