{"product_id":"axcaliber-cutpro-165mm-thin-kerf-tct-saw-blades","title":"Axcaliber CutPro 165mm Thin Kerf TCT Saw Blades","description":"\u003cp\u003eDesigned for a first class result in all natural timbers and man-made boards, these blades are the perfect choice for professional use.\u003c\/p\u003e\u003cp\u003eThey are particularly suitable for cordless circular saws. The thin 1.5mm kerf is 33% less than similar standard blades. They require less energy from your battery for a given cut resulting in longer runtimes and less strain on your machine. The alternate top bevel (ATB) grind gives you rapid progress through the cut and a quality finish. Axcaliber Cutpro circular saw blades use the latest production techniques and the finest materials. The blades feature micro-grained TCT tips. The laser-cut plates substantially reduce noise while cutting. A faint tensioning ring halfway across the plate indicates where each individual blade undergoes a pre-stressing to guarantee smooth running.\u003c\/p\u003e\u003cp\u003eThe bore size is 20mm.\u003c\/p\u003e","brand":"Axcaliber","offers":[{"title":"Extra Fine (52 teeth)","offer_id":54118285902171,"sku":"104008","price":27.35,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/104008_xl.jpg?v=1789773721","url":"https:\/\/www.axminstertools.com\/products\/axcaliber-cutpro-165mm-thin-kerf-tct-saw-blades","provider":"Axminster Tools","version":"1.0","type":"link"}
