{"product_id":"axcaliber-cutpro-tct-saw-blade-neg-rake-216mm-x-2-5mm-x-30mm-56t","title":"Axcaliber CutPro TCT Saw Blade Neg Rake - 216mm x 2.5mm x 30mm 56T","description":"\u003cp\u003eDesigned for a first class result in all natural timbers and man-made boards, this blade is the perfect choice for professional use. It is particularly suited for mitre saws and would also suit workshop circular saws where a fine cut is required, particularly in laminate or faced boards.\u003c\/p\u003e\u003cp\u003eThe 5\u003cspecial id=\"8\"\u003e\u003c\/special\u003e negative rake enhances safety by giving a smooth start and preventing the blade from grabbing. It offers the benefit of cutting at a more controlled pace for a neater result. The 35\u003cspecial id=\"8\"\u003e\u003c\/special\u003e alternate top bevel angle gives you an outstanding quality cut, even in timbers normally considered difficult. In effect this 35\u003cspecial id=\"8\"\u003e\u003c\/special\u003e angle creates a shear cutting action, resulting in a clean, splinter free finish.\u003c\/p\u003e\u003cp\u003eAxcaliber CutPro circular saw blades use the latest production techniques and the finest materials. The blades feature micro-grained TCT tips. The resin filled, laser cut plates substantially reduce noise while cutting. A faint tensioning ring halfway across the plate indicates where each blade is individually pre-stressed, to guarantee smooth running.\u003c\/p\u003e\u003cp\u003eThe bore size is 30mm, various bore reducing bushes are available.\u003c\/p\u003e","brand":"Axcaliber","offers":[{"title":"Default Title","offer_id":54118285705563,"sku":"103999","price":48.6,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/103999_xl.jpg?v=1789773702","url":"https:\/\/www.axminstertools.com\/products\/axcaliber-cutpro-tct-saw-blade-neg-rake-216mm-x-2-5mm-x-30mm-56t","provider":"Axminster Tools","version":"1.0","type":"link"}
