With a greater cutting depth this cutter is offered as an alternative to the standard cutter supplied with the Axcaliber and Axminster dovetail jigs and is suitable for a material thickness of approx 19-30mm.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
