Dovetail router cutters for use with Leigh 'D' series and Leigh Superjigs. The cutters can also be used for sliding dovetails and carcase construction. Produced using advanced technology on up-to-the-minute multi axis CNC machinery. Shanks made from SAE4140 steel hardened to Rockwell 45 HRC, renowned for its hardness and strength. A finely ground edge ensures a durable efficient cutter and a thick PTFE coating minimises resin build-up.
Shank Diameter 1/2" (12.7 mm)
X = Depth of Cut 32.5 mm
D = Overall Diameter 20.5 mm (13/16")
K = Cutter Angle 8°
Leigh Part No. 100 Web Attribute Set: Dovetail Router Cutters Router Cutter Type: Dovetail 8° D: 20.5 X: 32.5
EAN Barcode 5052511029075
