Dovetail router cutters for use with Leigh 'D' series and Leigh Superjigs. The cutters can also be used for sliding dovetails and carcase construction. Produced using advanced technology on up-to-the-minute multi axis CNC machinery. Shanks made from SAE4140 steel hardened to Rockwell 45 HRC, renowned for its hardness and strength. A finely ground edge ensures a durable efficient cutter and a thick PTFE coating minimises resin build-up.
Axcaliber
Axcaliber Dovetail Cutters for Leigh Dovetail Jigs
| Shank Diameter | 1/2" (12.7 mm) |
| X = Depth of Cut | 32.5 mm |
| D = Overall Diameter | 20.5 mm (13/16") |
| K = Cutter Angle | 8° |
| Leigh Part No. | 100 Web Attribute Set: Dovetail Router Cutters Router Cutter Type: Dovetail 8° D: 20.5 X: 32.5 |
| EAN Barcode | 5052511029075 |
