Axcaliber
Axcaliber Dovetail Cutters for Stair Jigs
SKU: 666070
£16.88
£14.07 Excl. VAT
  • Cutters for Staircase Jigs
  • Cutting angle of 5 to produce tight fitting joints
  • Select cutter diameter according to stair jig instructions
A choice of cutters for Staircase Jigs to suit various string and tread thicknesses. The cutters are dovetailed at an angle of 5 resulting in tight fitting joints between the treads/risers and strings when assembled and wedged. Select the diameter of cutter to suit your tread thickness and stair jig.
Shank Diameter 1/2" (12.7 mm)
X = Depth of Cut 26 mm
D = Overall Diameter 22.2 mm (7/8")
K = Cutter Angle 5°
Web Attribute Set Dovetail Router Cutters D: 22.2 X: 26
EAN Barcode 5052511029440
