Axcaliber
Axcaliber Edge Beading Router Cutters - 1/4" Shank
SKU: 666056
£20.28
£16.90 Excl. VAT
  • Manufactured using the very latest technology
  • SAE4140 steel shank hardened to Rockwell 45 HRC
  • Diamond ground micrograin tungsten carbide tip
  • Virtual mirror finish ensures durable, clean cutter
  • PTFE coating helps cutter to remain free of resin
Produce decorative beaded edges without the need for a guide fence. By setting the cutter carefully on both faces of the material a fully round corner bead can be made.
Shank Diameter 1/4" (6.35 mm)
X = Depth of Cut 12.7 mm (1/2")
D = Overall Diameter 20.5 mm (13/16")
R = Radius 2.4mm (3/32")
Web Attribute Set Beading & Reeding Router Cutters D: 20.5 R: 2.4 X: 12.7
EAN Barcode 5052511029358
