Axcaliber
Axcaliber Edge Breaking Cutters
SKU: 107554
£20.38
£16.98 Excl. VAT
  • Exact and controlled rounding over, perfect arris removal
  • Bearing guided for straight or curved edges
  • Essential prior to applying paint or varnish
  • Available in 1mm or 2mm radius
Edge Breaking router cutters round over sharp edges giving a very exact and controlled result. They are available in a choice of radii, all bearing guided for rounding straight or curved edges. These cutters remove the arris, leaving a perfect finish. If left as a sharp corner the wood may splinter or crumble. A sharp corner will not take a finish. You cannot paint a sharp edge. All cutters are 1/4 shank. PTFE coating minimises resin build-up. Available in 1mm or 2mm radius.
Shank Diameter 1/4" (6.35 mm)
D = Overall Diameter 20.5 mm (13/16")
R = Radius 1 mm
Web Attribute Set Beading & Reeding Router Cutters D: 20.5 R: 1
EAN Barcode 5052511123872
