The addition of decorative beads can add interest to your furniture projects but it is not easy to apply a bead set in from the edge of a rail using a router. The traditional method was by using a scratch stock, but by using this cutter and a router you will tackle the job faster with consistent results. With a 1/2
Axcaliber
Axcaliber Extended Shank Beading Cutter
| Shank Diameter | 1/2" (12.7 mm) |
| X = Depth of Cut | 16 mm (5/8") |
| D = Overall Diameter | 22.2 mm (7/8") |
| R = Radius | 3.2 mm (1/8") |
| Web Attribute Set | Beading & Reeding Router Cutters D: 22.2 R: 3.2 X: 16 |
| EAN Barcode | 5052511054022 |
