{"product_id":"axcaliber-fineline-ptfe-coated-handsaw-11tpi-500mm-pkt-5","title":"Axcaliber FineLine PTFE Coated Handsaw 11tpi - 500mm (Pkt 5)","description":"\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003ePackage deal comprises 5 Axcaliber FineLine PTFE coated handsaws, 500mm x 11tpi.\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003eThese razor sharp, triple ground teeth cut with amazing speed. The blades are 1mm thick steel with a low friction PTFE coating that also protects against corrosion. The teeth are electronically hardened and diamond ground. The saw is fitted with a heavy-duty two part comfort handle that incorporates 45\u003cspecial id=\"8\"\u003e\u003c\/special\u003e and 90\u003cspecial id=\"8\"\u003e\u003c\/special\u003e angles.\u003c\/p\u003e","brand":"Axcaliber","offers":[{"title":"Default Title","offer_id":54255638217051,"sku":"720622","price":67.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/720622_xl_229cc419-d057-473d-8b6e-15ff024297c9.jpg?v=1791242122","url":"https:\/\/www.axminstertools.com\/products\/axcaliber-fineline-ptfe-coated-handsaw-11tpi-500mm-pkt-5","provider":"Axminster Tools","version":"1.0","type":"link"}
