Package deal comprises 5 Axcaliber FineLine PTFE coated handsaws, 500mm x 11tpi.
These razor sharp, triple ground teeth cut with amazing speed. The blades are 1mm thick steel with a low friction PTFE coating that also protects against corrosion. The teeth are electronically hardened and diamond ground. The saw is fitted with a heavy-duty two part comfort handle that incorporates 45° and 90° angles.
EAN Barcode 5052511122837
