These razor sharp, triple ground teeth cut with amazing speed. The blades are 1mm thick steel with a low friction PTFE coating that also protects against corrosion. The teeth are electronically hardened and diamond ground. The saw is fitted with a heavy-duty two part comfort handle that incorporates 45
Axcaliber
Axcaliber FineLine PTFE Coated Handsaw 7tpi - 550mm (Pkt 5)
| Blade Thickness | 1.00 mm |
| Web Attribute Set | Handsaws |
| EAN Barcode | 5052511122851 |
