{"product_id":"axcaliber-fineline-ptfe-coated-handsaw-7tpi-550mm-pkt-5","title":"Axcaliber FineLine PTFE Coated Handsaw 7tpi - 550mm (Pkt 5)","description":"\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003ePackage deal comprises 5 Axcaliber FineLine PTFE coated handsaws, 550mm x 7tpi.\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003eThese razor sharp, triple ground teeth cut with amazing speed. The blades are 1mm thick steel with a low friction PTFE coating that also protects against corrosion. The teeth are electronically hardened and diamond ground. The saw is fitted with a heavy-duty two part comfort handle that incorporates 45\u003cspecial id=\"8\"\u003e\u003c\/special\u003e and 90\u003cspecial id=\"8\"\u003e\u003c\/special\u003e angles.\u003c\/p\u003e","brand":"Axcaliber","offers":[{"title":"Default Title","offer_id":54255639429467,"sku":"720620","price":69.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/720620_xl_db0683e6-739f-47d6-b3fd-1359b1734688.jpg?v=1791242125","url":"https:\/\/www.axminstertools.com\/products\/axcaliber-fineline-ptfe-coated-handsaw-7tpi-550mm-pkt-5","provider":"Axminster Tools","version":"1.0","type":"link"}
