These razor sharp, triple diamond ground teeth cut with amazing speed. The blades are made from 1mm thick steel and have a low friction PTFE coating that also protects against corrosion. The teeth are electronically hardened and diamond ground. The saw is fitted with a heavy duty two part comfort handle that incorporates 45
Axcaliber
Axcaliber FineLine PTFE Coated Handsaw
| Blade Thickness | 1.00 mm |
| Tooth Pitch \ tpi | 2.31 mm \ 11 tpi |
| Length of Blade | 500 mm |
| Web Attribute Set | Handsaws |
| EAN Barcode | 5052511064342 |
