An excellent choice for flush trimming or following a template, these cutters have the cutting edges placed at an angle to give a downward shearing action. This results in a very clean cut with minimum breakout. Bottom bearing cutter with 1/2
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
