{"product_id":"axcaliber-flush-trim-cutter-with-down-shear-bottom-bearing","title":"Axcaliber Flush Trim Cutter with Down Shear - Bottom Bearing","description":"\u003cp\u003eAn excellent choice for flush trimming or following a template, these cutters have the cutting edges placed at an angle to give a downward shearing action. This results in a very clean cut with minimum breakout. Bottom bearing cutter with 1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e(12.7mm) shank, 19mm diameter and 50mm depth of cut.\u003c\/p\u003e\u003cp\u003eAxcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.\u003c\/p\u003e","brand":"Axcaliber","offers":[{"title":"Default Title","offer_id":54117318852955,"sku":"951296","price":36.38,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/951296_xl.jpg?v=1789764974","url":"https:\/\/www.axminstertools.com\/products\/axcaliber-flush-trim-cutter-with-down-shear-bottom-bearing","provider":"Axminster Tools","version":"1.0","type":"link"}
