Axcaliber
Axcaliber Flush Trim Cutters Top Bearing
SKU: 666108
£17.98
£14.98 Excl. VAT
  • Perfect cutter for template routing
  • Bearing replaces need for guide bush
  • Bearing diameter same as cutter diameter
  • Greatly simplifies template making
  • Precision made cutters on multi axis CNC machines
  • High shear-cut angle for cleaner finish
  • PTFE coating helps minimise resin build-up
For template routing where the template is attached to the top of the workpiece, these cutters are an excellent choice. As with all Axcaliber cutters, the quality is superb with micrograin tungsten carbide tips and hardened steel shanks.
Shank Diameter 1/4" (6.35 mm)
X = Depth of Cut 19 mm
D = Overall Diameter 16 mm (5/8")
Web Attribute Set Trimming Router Cutters D: 16 X: 19
EAN Barcode 5052511029785
