{"product_id":"axcaliber-flush-trim-router-cutters-top-bearing-1-2-shank","title":"Axcaliber Flush Trim Router Cutters Top Bearing - 1\/2\" Shank","description":"\u003cp\u003eThese cutters have a bearing guide located on the shank. The bearing is the exact same diameter as the cutter. These are perfect for template work. With a template attached on top of the workpiece, the cutting edges remove excess material to leave an exact duplicate of the template. Using the template above the work piece improves visibility.\u003c\/p\u003e\u003cp\u003eObviously when using these cutters on a router table, the template is needs to be on the underside of the workpiece.\u003c\/p\u003e\u003cp\u003eAxcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.\u003c\/p\u003e","brand":"Axcaliber","offers":[{"title":"19 mm \/ 25.4 mm (1\")","offer_id":54117179359579,"sku":"666089","price":23.0,"currency_code":"EUR","in_stock":false},{"title":"19 mm \/ 31.75 mm (1.1\/4\")","offer_id":54117179392347,"sku":"666090","price":24.0,"currency_code":"EUR","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/666089_xl.jpg?v=1789764582","url":"https:\/\/www.axminstertools.com\/products\/axcaliber-flush-trim-router-cutters-top-bearing-1-2-shank","provider":"Axminster Tools","version":"1.0","type":"link"}
